Installation of Plasma TV and peripherals!! - newbie help!
Discussion in 'Televisions' started by WAYNE8056, Aug 20, 2005.
  1. WAYNE8056
    WAYNE8056
    Hi all,
    Can anybody recommend a decent company that will install (flush with front of wall) my 37" Panasonic 'Thiera', and also be able to have a 'cable free' front room (Via infra red remote control box - also fitted into wall, flush with front?).
    I will also be using a Denon (ADV-M51) DVD surround Receiver and Sky+ and want all of these to be situated under the stairs in the hall (out of the way for the wife!!)
    I have been quoted around £2500 which I believe is rather steep? Was looking at around £1000 - £1500
    Any help on this matter (websites etc) would be much appreciated.
  2. MAD ANDY
    MAD ANDY
    Nov 12, 2003
    304
    Cheshire
    +9
    Hi mate :)
    Unfortunately you have posted this in the wrong forum (hence no doubt the lack of response). Try re-posting it here on the Plasma forum and I'm sure you'll get back a decent response from guys that have done this
    http://www.avforums.com/forums/forumdisplay.php?f=82
    Hope that helps
    cheers
  3. WAYNE8056
    WAYNE8056
    cheers Mad Andy
