Installation concerns
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Happytab, Nov 4, 2005.
  1. Happytab
    Happytab
    Jan 10, 2005
    261
    Hi, I am thinking of switching from NTL to Sky+ with multi room - but here's the problem - TV is on an internal wall at the front of the house - back of the house faces south. I don't want cable run through the house so want them to go into the loft and down the same route the NTL cable goes. They say they are not insured to go into peoples lofts - any suggestions - I really can't handle a messy installation ! :lease:
  2. mjcairney
    mjcairney
    Oct 26, 2003
    7,319
    2
    137
    Airdrie, Scotland
    +1,105
    I'm thinking of upgrading from Sky to Sky+ and have exactly the same problem as you. I'm thinking of buying the cable and running it myself, letting them (Sky installers) do the the necessary cable terminations and connections.
    Cheers,
    Martin.
  3. TEDDYBASS
    TEDDYBASS
    If it was me I would ask the installers when they arrive to drill the holes into the loft but then you thread the cables and place loosely in position in the loft. Thread them down into NTL route and let them complete the installation. If you want you can then go back in the loft and clip the cable properly.
    It involves some work from you,(You do the work in the loft not them) but I cant see why they wouldn't co-operate.
  4. Happytab
    Happytab
    Jan 10, 2005
    261
    I guess an alternative is to pay for an independant instalation - does anyone know how much that would cost ?
  5. Happytab
    Happytab
    Jan 10, 2005
    261
    I spoke an independant installer today and they told me that I could probably use the exisiting NTL Cable but the sky+ would need two cables - can anyone confirm what was said ?
  6. Happytab
    Happytab
    Jan 10, 2005
    261
    Also - do sky+ box have audio out to connect to my surround sound ?
  7. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +272
    Yes, Sky+ has standard stereo out via Scart & phono sockets, and via an optical digital connection.
  8. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    yes you need two cables for Sky+ so that you can record one thing whilst watching another
  9. mjcairney
    mjcairney
    Oct 26, 2003
    7,319
    2
    137
    Airdrie, Scotland
    +1,105
    Or "Shotgun" twin coaxial cable which is available here
    Cheers,
    Martin.
