installation cd for Zyxel DMA 11000p
Discussion in 'Video Streaming Boxes & Services' started by normcatalunya, Jan 7, 2012.
  1. normcatalunya
    normcatalunya
    Jan 7, 2012
    4
    Hi..Hope someone can help /point me in right direction.Was given above adapter for christmas and up til now just used it to play audio files off a usb stick thro TV.Now got a homeplug system and was all eager to setup the links to my pcs etc ..only to find wife has thrown out box it came in together with installation cd!!!Doh!:suicide: ..which I believe is needed to install DiXim Media Server???
    Tried to find a download link for this without any success..
    Help please and thanks in advance
    Norm to
  2. next010
    next010
    May 29, 2005
    10,698
    163
    +2,086
    Dixim is just a UPnP/DLNA server so in theory any server should work as a replacement, try Serviio.
    Serviio also has a transcoder so it should help with the formats not supported by the DMA-1100.
  3. normcatalunya
    normcatalunya
    Jan 7, 2012
    4
    Thanks for that .Will try Serviio
  4. normcatalunya
    normcatalunya
    Jan 7, 2012
    4
    Hi..Have installed and opened Serviio console..added folders and under the status tab serviio selects ..
    87.111.159.3 DiXim Media Renderer Generic DLNA profile
    The DMA 1100p acknowledges the Serviio server but the selection is greyed out and when selected states"not authorised"
    Any pointers please..
    Thanks again
    Norm
  5. next010
    next010
    May 29, 2005
    10,698
    163
    +2,086
    Not sure, Serviio auto authorizes any DLNA client, it could be there is some compatibility issues (DLNA is rife with these), you could try asking on the Serviio forum for help and they might be able to get to the bottom of it and create a custom profile for the DMA-1100.
    As for other options there are plenty of other servers to choose from that you can try though some are commercial software like Mezzmo, Twonky (according to Google this works), Wild Media Server, they all have demo versions you can test with.
  6. awink1
    awink1
    Feb 27, 2006
    5,284
    +305
    Another dlna server that has served ;) me well over the years is TVersity which also has a free version.
