instal problems Pace BSKYB 3100
Discussion in 'Sky Digital TV Forum' started by JIimmy, Mar 5, 2005.
  1. JIimmy
    JIimmy
    Jan 24, 2004
    99
    have just installed a new quad LNB to the dish
    Connected two inputs to above (new) box and second channel will not lock
    have swapped the inputs and this shows good strength & quality off both of them on the 1st channel so problem appears to be the box
    help please
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    It's not that unusual.
    Some people have reported the second tuner being active right from installation/activation while others (like me) have had to wait around an hour for the second tuner to kick in after activating the SKY+ service.
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    A bad hard disk can cause that symptom too. Wait until it warms up, then see if it works. Did you jolt the Sky box whilst it was switched on ?
  4. JIimmy
    JIimmy
    Jan 24, 2004
    99
    OK I seem to have missed something here
    It is a self install, not by SKY
    Does this mean I have to inform them so they can activate it ?
  5. JayCee
    JayCee
    Jan 20, 2004
    23,989
    Lanarkshire
    +2,614
    Yes, you do, call the number on your viewing card.
  6. JIimmy
    JIimmy
    Jan 24, 2004
    99
    So, until I get activated by SKY, the second LNB will never lock ?
    Sorry if you think this is silly but I don't want to make a total fool of myself with SKY
  7. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Don't forget that you have to pay SKY £10 a month to use the SKY+ recording functions, without them the second tuner is redundant anyway.
    The subscription is waived if you have at least two SKY premium channels (SM1, SM2, SS1 or SS2).
  8. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,397
    Bradford, West Yorkshire.
    +325
    JIimmy,
    Regardless of whether the box & card have been paired, the second tuner should still detect it's receiving a signal. Always been that way in my experience.
    I suppose it is possible that Sky's software could prevent the second tuner from showing a signal but if all's well with the installation it is receiving a signal.
    You do need to phone Sky to 'pair' the box & card and subscribe to the relevant package to get the recording facility 'free' (!) or pay an additional £10 pcm.
    Also, Nick's correct - HDD failure can cause this symptom.
    Is this a new system?
    A. Dork
  9. JIimmy
    JIimmy
    Jan 24, 2004
    99
    yes it is a new system
    got the box about two weeks ago
    as I said, the second feed is good cos when I swap them over, the box still works
    its just the second channel will not lock when you view it on the system set up
    whichever LNB input I use
    the other two of the four go downstairs where they also work ( one at a time)
    when pluggrd into the old SKY box
    could be software locked I suppose otherwise I would be getting the record facility for nowt
    can't see SKY letting that happen :) :) :)
  10. JIimmy
    JIimmy
    Jan 24, 2004
    99
    Spent some time on the phone with SKY this evening
    They recognised that only one channel was locking and suggeted that it was one if two problems
    The first was that the box I bought had an older version of the software on it - a common problem they said with boxes from NON SKY sources, although they did admit it happens with their boxes too, if left in their warehouse too long
    They talked me through the software update procedure
    Befor signing off, they said that if that did not clear the fault, then it would be as Nick suggested - a hard drive fault
    Updated the software and tried it out- same fault :thumbsdow :thumbsdow :thumbsdow
    Thought shoot or bust and did a Sytem Reset - the fault cleared :clap: :clap: :clap:
    I'm now £10 a month worse off (as soon as the second card for the old box arrives)
    Thanks to all for your help :thumbsup:
