Inside the Sony NW-HD3
Discussion in 'Headphones, Earphones & Portable Music' started by Qs'Tree, Feb 26, 2005.
  1. Qs'Tree
    Qs'Tree
  2. Stahlhart!
    Stahlhart!
    THX4that!
  3. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,688
    London
    +483
    It shows in the HD1 manual how to open it up in order to dispose of the battery. Two little screws, one either side and the whole thing simply slides out.
    The beauty of this is you can replace the battery should you so wish yourself. What might be better is you can fit a bigger HDD inside ;)
  4. SuperSaiyan4
    SuperSaiyan4
    Feb 19, 2005
    2,245
    48
    +49
    someone told me that inside the NW-HD1 there is an airbag to protect the hard drive is this actually true???
