inset cinema screen
Discussion in 'Home Cinema Building DIY' started by nathsea, May 25, 2003.
  1. nathsea
    nathsea
    Apr 26, 2003
    918
    +24
    hi all,
    Just a quick question I`m about to start plasterboarding my dedicated room and was wondering what your thoughts are on insetting the screen in to the plasterboard ie. I will cut a large hole out of the plasterboard and then mount my home made screen flush with the rest of the plasterboard (does that make sense?) Woudl this work ar should I just mount it on the wall?
    Many Thanks for your time
    Nathan
  2. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,242
    +157
    Couldn't you achieve the same effect with a lot less hassle by simply painting the screen and its surround onto the finished plaster surface?
    Bert
    www.bertcoules.co.uk
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Take a look at X3ELS's (Elliot) room.
    This should give you some ideas, as he has put his speakers behind his screen such that everything is flush.
