Insert Time/Date Onto Video
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Dimension2006, Mar 12, 2006.
  1. Dimension2006
    Dimension2006
    Jan 16, 2006
    45
    Hi all,
    I really need some help...
    I recently recorder some camcorder footage and forgot to add the date/time code :suicide:
    Is it possible to add this now???
    Any advice would be much appreciated!!
  2. Brian110507
    Brian110507
    Yes - depending on what editing programme you are using you could add it as a small subtitle after reading the info from your video properties - - or you could try this :-
    http://www.dts8888.com/vDTS/vdts.htm
  3. Roy Mallard
    Roy Mallard
    if you can capture it from an analogue card then you can actually have the video info data playing back on screen on most cameras, once again there is a dearth of information on what kit you are using, so it is really hard to offer more constructive help.
