Input Type
Discussion in 'Projectors, Screens & Video Processors' started by sks, May 31, 2004.
  1. sks
    sks
    My Panny AE500 has component, scart, and composite, and S-Video. Can someone rank these in order of which is best ?
    Also I cannot get prog scan to work with my rubbish compacks dvd player (it is definitely prog scan). Does it only work with a certain input type?
  2. venkman
    venkman
    Jan 17, 2003
    82
    Keighley
    +4
    component -> scart (assuming it's RGB) -> s-video -> composite
    Prog scan will only work with a component connection.
  3. sks
    sks
    That'll be why it all goes funny then when I choose prog scan :)
    I'm currently using composite, so time to buy some component cables. Any recommended stores?
  4. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
  5. venkman
    venkman
    Jan 17, 2003
    82
    Keighley
    +4
    Can't really think of any places I would recommend, try searching the forums as I'm sure it will have been discussed many times.
    BTW, your ae500 also has dvi which is better than component (generally). Instead of getting component cables you could put the money towards a dvi player + cable.
  6. sks
    sks
    how much is a dvi player? Are we talking over £100 cos I just bought a prog scan cheapie recently, which I'd get about 50p for second hand.
  7. sks
    sks
    I'll check out that site Steve cheers.
  8. jamiev
    jamiev
    Jan 4, 2004
    924
    +35
    check out tvcables.co.uk for component leads, they do 10m profigold for £36!!
