Input 2 Signal Strength=zero
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Jon12345, Jan 23, 2008.
  1. Jon12345
    Jon12345
    Sep 12, 2002
    171
    +3
    I have a signal on Input 1, but Input 2 Signal Strength is zero. Is this normal or have I got a fault?
    Thanks,
    Jon
  2. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
    No it certainly isn't normal.
    Have you tried swapping the connections around/
    If you then get a reading on Input 2 but zero on Input 1 the LNB is probably the first thing to suspect, but check all connections of course
