innterconnects and cables!!!!!!!!!!!!!
Discussion in 'Cables & Switches' started by mongo, Jul 22, 2001.
  1. mongo
    mongo
    i have a ixos 103 10meter long cable with gold lockbel ends is this good for connecting to my sub???
    it says the number on the cable it is red i do not no wot exact it is i got it for a home cine shop on a clearance i think it is custom made also got a s-vid on as well 10 meters with best end that ixos do also this is blue wot is best for connction rgb ( i think) or s-vid????
