Initial Settings for Panasonic S30?
EnfieldBlue
Hi all,
Just ordered a Panasonic VIERA TX-P42S30B and would like some advice on the initial settings:
  • What settings should I adjust to 'run-in' the TV?
  • Will I need to adjust the green levels, as discussed in the AV Forums Review, and is there an easy way to do this? (They mention high levels of green and going into the Service menu to adjust, which I assume is either tricky or only for engineers.) Or are the out-of-the-box modes going to be good enough for an uneducated fool like me? :)
Also, my brother will also be getting a set and he'll use it for quite a bit of gaming - is there anything I should tell him to avoid? (Thinking of possible image retention here.)
Many thanks.
SVS Prime Wireless Pro Powered Speakers - Review Coming Soon
