Initial chargin of batteries... how long?
Discussion in 'Mobile Phones Forum' started by Mossyman, Jul 1, 2005.
  1. Mossyman
    Mossyman
    Any current thoughts on this? :lease:
    Do you still need an interrupted 12 hour plus charge?
    many thanks!
    Mossyman :thumbsup:
  2. kourosh
    kourosh
    Feb 6, 2005
    14,676
    Portsmouth
    +1,048
    you still need at least 12 hours,i would just leave it charged when ever possible for a couple of days :thumbsup:
  3. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    An 8 to 12 hour charge was the norm for nicads, but I am not so sure it applies to Li-ion cells.
    A number of phone instructions make no reference to a time, other than it should be 'fully charged' before first use.
    If you also consider that current chargers will fully charge the battery in typically less than 1 hour, there does not appear to be any reason to let it continue after this time.
    I just fully charge, and I have never had any problems with early battery failure.
  4. EnigmaCode
    EnigmaCode
    Dec 16, 2004
    265
    +21
    yes there is. its called trickle-charging.
  5. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    Obviously.
    But in the context of 'first charge before use' what is the purpose purpose of letting it trickle charge for an extra 8/10/16 hours etc after it is fully charged?
