We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Infuriating Bittorrent wireless problem
Discussion in 'PC Gaming & Rigs' started by t-force, Oct 31, 2005.
  1. t-force
    t-force
    May 2, 2001
    1,880
    Southampton, UK
    +156
    Not sure if I should be posting on this forum or the Home Entertainment PC one. My PC is giving me huge amounts of grief when I'm using BitTorrent software. Everything goes along fine for a while (it can be a couple of hours, or only 5 minutes), but then my wireless connection just stops sending and receiving data. The connection is still there to my router, but nothing can access outside (be it email, firefox or whatever). The only way to get back up and running again is to go to "View wireless networks", and then disconnect from the wireless network, then repair the connection, and then reconnect to the wireless network - if I just repair, then it can't disable my wireless adaptor and I have to reboot. It only happens using BitTorrent (I've tried several different clients, and they all exhibit the same problem).
    I've tried applying the 4226 patch, and that's not really helping - when I check my event log, 4226 isn't showing as a problem anyway.
    Anyone got any ideas? This is really driving me potty!!
  2. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    Dont know how to fix this, but it could be that the constant streaming is too much for any wi fi conection.
    You may need to pause it for a while.
    I recomend for Bit Torrent you use a hard line.
    I do and have no probs.
  3. miketrim
    miketrim
    Jan 11, 2005
    688
    +8
    I use BT via wireless all the time. never had a problem
  4. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    I had a similar problem to this and it was down to a firmware fault on my Belkin Wireless Router, what kind of Router are you using?
  5. ChrisN
    ChrisN
    Oct 21, 2003
    836
    28
    +60
    Me too. Exact same problem caused by a firmware fault on a Belkin wireless router. Got a D-Link now and everything is fine.
  6. t-force
    t-force
    May 2, 2001
    1,880
    Southampton, UK
    +156
    I'm using a DLink router, and the router itself seems to be fine, as when the problem occurs, the laptop we have in the other room carries on working without a hitch.
  7. neilo
    neilo
    Apr 18, 2002
    1,569
    38
    +21
