Infrastructure Mode - no connection
Discussion in 'PS Vita Forum' started by -Spike-, Sep 3, 2005.
Tags:
  1. -Spike-
    -Spike-
    May 17, 2001
    1,622
    E.Sussex
    +296
    Just wondered if anyone else has had any problems connecting to their wireless access point / router?
    I'm using a Linksys WRT54G with broadcast SSID off and WEP encryption on.
    If I scan using the PSP it detects the wireless network but I always get a connection error when I test the connection.
    I've managed to find many other threads on other forums but have yet to come across a resolution, some have suggested turning the SSID broadcast on while other suggestions have pointed to turning WEP off - something which I'd rather not do.
    I've also setup the connection manually but still no connection.
    Any suggestions please?
  2. calibos
    calibos
    Aug 4, 2000
    931
    Ireland
    +33
    set the router to b only or b+g mode (if you have other wireless equipment that use the G wireless standard)
    PSP only supports the b wirelss standard
  3. zoidy
    zoidy
    Mar 18, 2005
    693
    Surrey
    +53
    Hi Spike,
    if you are using 128 bit WEP then that may be the problem. Try reducing the encryption (but not turning it off) if you have that option in your router and test. I think the PSP does not support 128 bit WEP.
    If you have WPA security on your router try that aswell (if you have updated the PSP to v2.0).
    Cheers,
    Pete.
  4. -Spike-
    -Spike-
    May 17, 2001
    1,622
    E.Sussex
    +296
    Guys, thanks for the replies.
    Got it working but only after broadcasting SSID and disabling WEP.
    I'll give both suggestions a go.
    Once again thanks for taking time to reply. :)
  5. bellso
    bellso
    Apr 21, 2004
    1,476
    Leeds, U.K.
    +319
    deffo go down the WPA route - is safer than WEP in the 1st place! and is easier to do, you just enter any password [ie nopt some random generated confusing thing!!]
    got mine working, but my Macs [desktop and laptop] seem to have a problem when it is on - ie they wont connect at all - is weird. wont use in the house, but will come in handy when out and about.
  6. bellso
    bellso
    Apr 21, 2004
    1,476
    Leeds, U.K.
    +319
    doh! sorry - double post :(
