brymbo76
Established Member
Hello. I'm brand new to AV Forums,
I just bought a new TV which only has one "Mini" Scart socket but includes a converter lead to a standard Scart socket to connect your old equipment.
I have two items of equipment I used to connect up to my old TV through Scart and I thought I could consider using a Scart Switch I have got as I only have the one input but two items to connect but then I thought to save switching the inputs, I may as well make use of one of the unused inputs.
Looking on ebay, I thought a Scart to VGA adapter would be the simplest solution but am not sure if it will definitely work or not? I have read that it will be unable to transfer signals from VGA to Scart but will work from Scart to VGA, but does it carry audio signals as well or do I need a separate audio lead for it? This is about £4+
I alternatively could buy a Scart to HDMI, but that requires an extra power socket as the converter includes a power adapter. These seem to start at around £15
Or I could convert Scart to Component but these are more expensive again.
Or I could buy a Scart to USB but the adapter I have seen has a USB plug one end and 3 phono sockets the other end and this requires converting the phono sockets to phono plugs then the phono plugs to Scart plug and it just seems a little messy.
Please can anyone tell me whether the Scart to VGA will work or alternatively, which of the other alternatives would you recommend instead?
Hope you are able to advise me on this.
Thanks.
Thanks.
