Inform Me
Discussion in 'Blu-ray & DVD Players & Recorders' started by drdaredevil, Jul 9, 2004.
  1. drdaredevil
    drdaredevil
    I am a little confused why anybody in their right mind would buy a dvd recorder compared to a dvd burner for your computer. I do not know much about recorders but i thought that they can't copy copywritten material? There are loads of programs on the computer that decode dvd's making copywritten dvd's able to be copied. Please, I am a noobie to this forum, but let me know why soo many people like recorders compared to dvd burners.
  2. muzza1uk
    muzza1uk
    Jun 25, 2004
    187
    +6
    I guess Dr. because most people are using them to record from TV or Satellite and they don't have/want a PC in the living room. Sure PC burners are more flexible in their uses and allow all sorts of hi-jinxs but DVV-Recorders really are a sensible step forward from VHS now that the media and equipment is cheaper.
    Muzza1
  3. drdaredevil
    drdaredevil
    Hmm.... Why don't they just get TiVo or something like that then?
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,855
    Warwick
    +2,773
    Because a DVD recorder allows you to play DVDs...
  5. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    846
    19
    leeds UK
    +16
    I have both, the recorder under the tv is ideal for archiving films and other items I wish to keep, whilst its hard drive is equivalent to owning a tivo, except the picture quality is better. This is easy and quick to use.
    I also have a dvd recorder in the computer, which is ideal for data storage, creation of edited camcorder dvd's, slide shows, and for "backup" of commercial dvd's. This would be a nightmare to use for recording tv and anyway my tv card only has poor mono sound, and no access to the sattelite in stereo anyway.
    As I purchased a pc dvd recorder that can also play and record to ram discs they are compatible with each other should I need the facility.
    Personally I think that both are essential now.
  6. jesmat2003
    jesmat2003
    Mar 8, 2004
    74
    They did get "something like that" - it's called a DVD Recorder.
    I bought a DVD Recorder for ease of use at recording television programmes. It's easier to set-up a DVD Recorder next to my telly than move my PC around the house every time I want to record something. My PC is also a few years old and with an 18GB hard drive and Pentium III 550 couldn't cope with a DVD Burner anyway. As for the "back-up" up commercial DVDs:
    1. A [removed-lynx] hooked up to another player would work.
    2. With dual-layered blank discs fairly new and untried, backing-up a commercial dual-layered disc on to a blank single-layered disc has its own problems.
    3. If I want a DVD, I am perfectly happy to shop at Play.com or other online retailer and pay £10 - £15 for an original disc.
  7. Rasczak
    Rasczak
    Apr 3, 2002
    21,855
    Warwick
    +2,773
    I couldn't agree more!
