InfoLithium Batteries.
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Gorthaur, Jul 28, 2003.
  1. Gorthaur
    Gorthaur
    Got an old Sony Hi8 TR713E which uses InfoLithium "L" series and an AC-V700 charger.
    I'm hoping to upgrade to a digital CC in order to use "L" series with a Sony CC.
    Anyone know if my "L" series would be compatibile with any of the other series? "M" seems the nearest size etc, but I just don't know. If the "M" series can fit into my charger that would be something too.
    If no to all, then it will probably stop me looking at just Sony for a CC replacement!
    G.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,258
    Rainham Essex
    +2,403
    I've got a Sony TRV900E DV camcorder that uses the infolithium L series batteries. This is now an old model, but it shows that you might be able to get a current DV cam that will use your batteries/charger.
    Mark.
  3. Gorthaur
    Gorthaur
    Thanks for that.
    It gives me hope at least that I might not have to shell out on new batteries, charger!
    G.
