Infocus X3 Projector and Xbox 360
Discussion in 'Xbox Forums' started by Jgrande, Mar 28, 2006.
  1. Jgrande
    Jgrande
    Mar 28, 2006
    4
    Anyone using an infocus projector out there with their xbox360? What adapters or cables did you use to get the best picture? Heres how mine is currently set up...
    1)composite=xbox 360
    2)s-video=tivo
    3)m1port=computer
    Im thinking of getting...
    1) M1 to component adapter
    2) S-video to component
    3) ???VGA to component using the cable currently connected to my pc
    Any Suggestions?
  2. Jgrande
    Jgrande
    Mar 28, 2006
    4
    Well I went with the m1 to component adatper and the picture is just incedible. only problem is that i now have to manually swap cables when i want to hook up the computer. would be interested in anyone who has used s-video to component and how that compares to the m1 port. only reason i would do that is to avoid the cable swapping. Or maybe there is some kind of 3rd party switcher?
  3. ush flynn
    ush flynn
    Nov 25, 2005
    2,617
    Bromley
    +126
    our infocus screenplay 5000 has component on it already, the vga is used by a laptop and the hdmi by a dvd player... to be honest, im so happy with the 360 on my tv (philips 32pf9830) that i cant be bothered taking out the power brick and cables to try it on the pj! (downstairs)
  4. jcb1888
    jcb1888
    i have an x1 which i use a component to vga and it looks just as good as on my panny 42pv500
