Infocus X10 IN82 won't power on. New bulb sign
motoroller
My Infocus IN82 stopped powering up. I assumed it was the bulb and bought an eBay bulb for 90 pounds.
The problem is, whichever bulb I use in the projector, it just gives me the "bulb warning" light when plugged in.
Is this a known issue? Could it be a capacitor, or even the entire ballast?
I'd rather spend a bit more on this projector than buying an entirely new setup.
SOD151
Motoroller,
Did you ever get to the bottom of the IN82 lamp issue? I have something similar. Bulb went (or so I thought) and I got a replacement one. I fitted it and powered it up. It did come on for a few seconds but then the red warning light came on. Not sure if the new bulb has blown or if there is another issue.
I have cleaned out all vents and filters inside so it's not a temperature / cooling issue.
Can anyone help?
SOD 151
Podcast: The Best TVs and Projectors of 2020, plus AV, TV Show & Movie News & Reviews
