INFOCUS Vídeo projector Infocus Screenplay 5000 HD Ready vs PANASONIC PT-AE700
Discussion in 'Projectors, Screens & Video Processors' started by cmnunes, Jun 28, 2005.
  1. cmnunes
    Jun 2, 2005
    I was looking for some advice.
    I am looking for my first projector, and from all i had read, and for the budget i have (€1.500), i got this 2 pre-choices.
    INFOCUS Vídeo projector Infocus Screenplay 5000 HD Ready - € 1.529,00
    PANASONIC Video-projector PT-AE700 - €1.558,00
    I am thinking in buying the pixmania (www.pixmania.com).
    From what i had read, DLP produce a better image over the LCD at the same resolution, the thing is that i DLP with the resolution of any of this 2 is more expensive.
    And it seams that the 3x LCD make the anyoing vertical banding almoust disapear.
    I would like if any of you could help me decide between this 2, or if it is any other projector that i should consider.
    Thanks in advance any help anyone can give.
