Infocus SP 4805 Connection Problem
emmahip
I'm a bit confused - hopefully this isn't a daft question but I would really apreciate some help!
:lease:
I have got a Pioneer 656 dvd player with component video out and I have purchased a convertor box to make this a hdmi signal.
When I connect my hdmi - dvi cable and then plug into the m1-dvi adaptor on my infocus sp4805 I get no signal.
All the individual parts work as I've tested each with th projector or my Panasonic Viera TV.
Will replacing the hdmi-dvi cable and the dvi-m1 adaptor with one m1 - hdmi cable solve my problem? Or am I barking up the wrong tree and need to get a new DVD player? (if so it would need to be multi-region and not too expensive)
Many thanks for any help!
:suicide:
Warpaint
Why not just plug the DVD into the projector with a component cable?
There is no point converting component to HDMI then sending it to the projector.
p5yco
i have a similar setup mate, same projector but pioneer 575 dvd player, connected via component this gives a great picture, if you have two component devices you wish to connect try using the the component switching on your av amp if you have one.
emmahip
Thanks guys - I used to connect via the component but a mate has been using the m1 connection and it gives a noticeably better picture.
I am hanging out for digital but waiting to see who will win out HD or BluRay before I buy a new player.
Just got an email back from Cable Universe where I bought the adaptor asking how long the dvi - hdmi cable i'm using is. They think it should work :eek: guess if I have to replace that cable it wouldn't be too bad....
Will let you know what they say........
Just had a phone call (hats off to this company - they are really helpful!) should work but doesn't so have put it down to an incompatibity problem and I can return it.
Back to the old drawing board then.......
