infocus ls110
Discussion in 'Projectors, Screens & Video Processors' started by meva, Oct 30, 2001.
  1. meva
    meva
    Feb 20, 2001
    354
    cornwall,uk
    +14
    This looks interesting
    www.infocushome.com
    anyone know if this is the same projector as the Toshiba
    mt5.
  2. Guest
    I can find absolutely nufink in the Web about the Tosh MT5, but the pictures that I have seen in some magazines look very much like the LS110
    The specs for the LS110 say it has a 6-segment, 4 speed colour wheel. Is this good? Does this overcome the Rainbow effect?
    The specs also say it is a Duel-mode 16:9 4:3 system, which sounds very similar to the SIM250DM. I do hope it doesn't have that price tag too!
    I'm not effected by the Raindow effect myself, but I wouldn't want to show off my system to people who can see it - I would be soooo ashamed!!
  3. meva
    meva
    Feb 20, 2001
    354
    cornwall,uk
    +14
    Hi Meat,
    Glad someone else is interested in this. U.S msrp is $4999 ( i.e considerably cheaper than the Sim2 ).
  4. Guest
  5. Grubert
    Grubert
    Jun 15, 2001
    601
    28
    +72
    0,7" DLP matrix
    Resolution: W-SVGA Chip 848x480 (16:9 Format)
    Brightness: 1.000 ANSI-Lumen
    Contrast: 600:1
    Dimensions (W x H x D) 260 x 85 x 280 mm
    Weight 2,6 kg
    Bulb life up to 2000 hours
    Bulb 270 W
    Video compatibility NTSC, PAL, SECAM, compressed HDTV
    Lens: Zoom 1,25:1, f=25,5 - 31,2 mm
    Digital vertical keystone correction
    Image size (Diagonal) 1,5 - 4,9 m
    Projection distance 0,9 - 3,5 m
    Inputs MI-D/A, Audio, S-Video, RCA
    Outputs only with Connectionbox
    Built-in speaker
    Extras: Connectionbox, ideal for wall or ceiling mounting
    Accessories: remote, cables, batteries, manual :rolleyes:
