InFocus LP 540 - good entry level projector?
Discussion in 'Projectors, Screens & Video Processors' started by YattaDog, May 28, 2004.
  1. YattaDog
    YattaDog
    I'm thinking of buying a projector. Since this is my first foray into a home theater, I'd like to start at a mid-entry level projector.
    The room in planning on setting up for my theater has some ambiant light, so the ANSI of the LP540 is attractive to me, as is the native 1024X768 resolution.
    What are your thoughts on this model? Any recommendations of a similar projector at or below this price range (~$1400 US). I don't want to go any higher price-wise.
    Thanks.
