InFocus 5700 oddity...
Discussion in 'Projectors, Screens & Video Processors' started by rjs1974, Jun 7, 2004.
  1. rjs1974
    rjs1974
    Twice in the last few weeks, when I have powered up my InFocus 5700 PJ, it clicks a bit, fires up audibly, but produces no image. It makes a kind of whirring sound but nothing appears.
    If I then pull out the power lead then try again, it fires up perfectly.
    Any ideas what is happening?
    Thanks all.
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    I dont know what is happening, but this is the sort of thing that is worth watching and definitely worth getting looked at before the warranty is up....
    ad
  3. Lepton
    Lepton
    Mar 26, 2004
    69
    11
    Greece
    I had something similar, luckily only once till now!
    After watching a movie, I pressed the Power button to turn the PJ off. The green LED started blinking, as it is supposed to, but the lamp did not turn off! I waited for a long time, and then I tried turning the PJ back on, but, as the manual specifically states, no operation is allowed while the green LED is blinking. Saying my prayers, I pulled the plug, put it back on and when it started warming up again, I turned it off properly. Luckilly, everything still works fine, but if anything like that happens again I will notify my dealer.
  4. Richard Moore
    Richard Moore
    Sep 14, 2003
    72
    Watford
    I've had this once so far. If it happens again it's warranty check time...
  5. AMCross
    AMCross
    Dec 3, 2003
    6,018
    Livingston,Scotland
    +208
    Sound like the colour wheels bearings.
    My two Infocus x 1 are in for repair should be warranty but they claim that because they are used in a smoking enviorement then its not :mad:
