infocus 5700. dvi/m1 or 3 component?
Discussion in 'Projectors, Screens & Video Processors' started by [email protected], Jan 15, 2008.
  1. thecornfords@go
    [email protected]
    Jan 4, 2008
    737
    bexleyheath
    +80
    hi all, just wondered if anybody knew which gave a better picture on a infocus 5700. would it be m1 or 3 component?:suicide: many thanks, chris.
  2. thecornfords@go
    [email protected]
    Jan 4, 2008
    737
    bexleyheath
    +80
    please help as im buying the cable tonight!!
  3. binbag
    binbag
    Jun 16, 2004
    1,717
    North Kent Coast, SE UK
    +81
    Depends on all sorts of things. Not least the quality of your source over a given output. At this stage if I were you I'd get both. However if you really are limited to one then it is generally said that the digital cable delivers a picture with greater clarity and the component can have greater colour fidelity but you'll probably have more variation at the source than via the cable (assuming that you get a quality analogue cable).
    I use the VGA port over RGBHV from my scaler to my 5700 and it also carries YUV for component HD signals.
