Infocus 4805 Screen Trigger
Discussion in 'Projectors, Screens & Video Processors' started by buddyj, Aug 26, 2005.
  1. buddyj
    buddyj
    Apr 22, 2002
    53
    Leeds
    Does anyone know if the screen trigger on the 4805 gives a pulse to raise and another to lower the screen, or if it's a constant current from the trigger while the PJ is switched on, which then stops when switched off?
  2. binbag
    binbag
    Jun 16, 2004
    1,717
    North Kent Coast, SE UK
    +81
    According to the manual (page 5) it provides a constant output while the projector is on.
    To use you should remove the safety plug and enable the function in the System menu.
