Info wanted on Notebook PCs
Discussion in 'Nintendo Forums' started by Miyazaki, Apr 24, 2005.
  1. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    Thinking about getting a notebook pc for the missus. It is just for uni work and eventually for teaching, so just needs to be able to run word, powerpoint etc on it.
    I would like it to have a wireless network card and a dvd rewriter, network card a must, rewriter a plus.
    Any ideas? Looking to spend about £500
    had a look at dell, but don't really fancy them TBH, won't touch pc world with a bargepole either.
    Any help would be great. Many thanks.
  2. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    Put this in the wrong forum. :rolleyes: Could a mod please move this to pc gaming or general chat as you see fit. :thumbsup:
  3. Hitby
    Hitby
    Feb 2, 2005
    4,679
    Middlesbrough
    +518
    I know it's a bit out of your price range (but not by much) have you considered an iBook? I use a 12" powerbook and have never looked back at a pc since receiving it? The 12"ibook is currently £699 but you'd qualify for the Student price which'll knock a fair bit off, dvd cd/rw drive built in, wireless etc, and what's more you'll get iLife '05 with it!
    If you need any help just gis a shout.
    Dan
  4. jenic
    jenic
    Dec 10, 2004
    2,871
    83
    +179
  5. AML
    AML
    Jul 22, 2004
    4,985
    Tokyo
    +229
    Im also looking to buy a notebook PC for Uni work. And some possible gamin?
    I looked at several makers and the chepest with the most power seem to be Dell and IBM.
    Specs wise i looked at a Pentium M with about 512mb RAM, 40 or 60gig HDD, and a 64 or 128mb GPU.
    B5 or A4. 12" to 15" LCD. resolution between 1024X768 and 1600X1200.
    It can make a huge difference so think about exactly what you need.
    If u need good battery life then a pentium M is the best choice. You can get a good 3 to 5 hours from one of those. If u choose celeron, it will be cheaper but less reliable and less battery life.
    That should cost roughly 500 or 600 quid.
  6. jenic
    jenic
    Dec 10, 2004
    2,871
    83
    +179
    I have a toshiba laptop with a celeron proccessor which is very good. It can run some of the most advance games and is very reliable.
    I have to admit the battery life is shocking, 2 hours on a good day
