Info on Sanyo MDG-X5 MD separate ?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Chris Muriel, Jun 16, 2003.
  1. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,127
    Manchester
    +715
    I just risked buying a Sanyo MDG-X5 Minidisc unit.
    I have only the unit + photocopy of user manual +an optical connection lead.
    I could use at least the connections for the ribbon connector socket at the rear .
    It says it needs +5volts DC + 18 V ac to power it - but I have no idea of the required currents.
    The specifications just say "Power : supplied from the Tuner/amp".
    I am an electronics engineer so no problems if I had more information to work with.
    Interestingly, the ribbon cable/connector on my Aiwa XR-MD200 seems to be identical (but I'm sure the actual pin definitions (and probably the supply voltages) will be different .
    As this only cost me 20 quid, I don't relish forking out a similar amount to get a service manual.
    All help and info greatly appreciated.
    (I might also be interested in anyone selling the matching tuner/amp of course).
    Chris Muriel, Manchester.
