Info on Rotel 965BX Discrete CD Player
Discussion in 'Hi-Fi Stereo Systems & Separates' started by applebwl, Jun 17, 2002.
  1. applebwl
    applebwl
    May 11, 2002
    1,043
    38
    Wiltshire
    +17
    just picked up a Rotel 965BX Discrete CD Player. Can anyone tell me how the discrete version differed to the normal, as I can,t seem to find any info on the web
  2. MikeC
    MikeC
    Mar 14, 2001
    224
    Northants,UK
    +10
    applebwl
    i don't have any magazines etc any more from that period so i cannot be 100% sure but, when hifi blurb refers to a descrete
    version, it almost certainly means that the manufacturer has replaced the industry standard op-amps (simple line level
    multi-transistor output devices such as NE5534) with simpler and hence higher quality transistor equivalents.
    HTH.
  3. applebwl
    applebwl
    May 11, 2002
    1,043
    38
    Wiltshire
    +17
    MikeC
    Thanks for the info :)
  4. petrobas
    petrobas
    This was a killer cd player a few years back & still gives modern gear a run for the money.
    I have one still , fantastic machine.
