Info needed on Sharp XV-C20E
Discussion in 'Projectors, Screens & Video Processors' started by godi32, Mar 16, 2001.
  1. godi32
    godi32
    Hello again everybody,
    I can buy a Sharp XV-C20E projector for 750£. What are your thoughts on this machine? I know it's not high-tech but will it give any viewing pleasure at all or should I leave it for what it is?
    Thanks for the advice,
    Dirk
    Belgium
  2. Guest
    Is that £750 new or second hand?
    I sold mine for £600 which is about the right price for a second hand model, so £750 would be a bit steep. If its new then its a bargain, You wont find a better price. I owned one for a year and its a great machine for movies, but you MUST be in a very dark room to get the best from it. For £750 you may find a higher spec LCD, second hand.
