Info for the Toshiba sd-2600 dvd player (multi-region)
Discussion in 'Blu-ray & DVD Players & Recorders' started by paedro, Nov 11, 2003.
  1. paedro
    paedro
    I have a Toshiba sd-2600 and am wondering if it is multi-region?
    I read on dvdrhelp.com that the sd-2550, sd-2600 and the sd-2650 are the same dvd player just different front panels and also that they are multi-region capable. However, i have not been able to find anything regarding on how to do it. So if anyone can help me make this thing multi-region, it would be greatly appreciated.
    I have searched everywhere (including these forums) and have been confused whether it is actually possible.
    If it helps, i live in Australia (i heard that this particular dvd player is only available/different in Australia.
    thanks in advance
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    Hi paedro and welcome to the forum.
    I have a Toshiba SD-900e (UK) and that was upgraded to multiregion before I bought it by the shop. They did this with a firmware update. I would therefore think that if you DVDP is capable of MR then it would be upgraded in the same way. If you can find it on the internet and have a CD/DVD recorder on your PC/Mac then you could download the file and create a disk and do the upgrade yourself. If not then find a dealer that has the disk.
    Be aware that when upgrading the firmware you can 'kill' a player if it goes wrong. It is then back to Toshiba for a repair. This would also make any warentee void, so the repair would be chargeable.
    Mark.
  3. Harry T
    Harry T
    When making enquiries re purchasing my DVD players, I was told that all Toshiba's in Australia, are not multi-region out of the box and they all can be made multi-region at any Toshiba Service Centre.
    That was too much trouble for me and didn't investigate any further.
    But a quick search on the internet, it appears that is it the same firmware update as the SD220E.
    Try here
    http://www.geocities.com/its_yahell/toshiba_sd220e.html]or here (different instructions)[/URL]
  4. paedro
    paedro
    thanks guys for your feedback
    i will llok further into the firmware upgrade.
    i didn't realise that the firmware for the sd220e is the same for the sd2600.
    i will try to find out if i can get the firmware upgrade disc from a dealer and then if not, try and convince my girlfriend to let me upgrade the flash in her dvdp :)
    thanks again guys
    p.s. i didn't know about these forums until this problem came along but i can assure you that i will be hanging around :)
