Info about the newToshiba 32ZD36 - please!
Discussion in 'General TV Discussions Forum' started by zingo, Nov 1, 2003.
  1. zingo
    zingo
    Hi everybody!
    I´ve been searching the web for information about the new Atrium series, but I have not found anything usefull yet.
    Have someone tryed it, own it? Does anyone have the technical specification? Have it been realesed yet?
    I´m most interested in the technical specification.
    Thanks in advance!
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Perhaps you could try Emailing toshiba?
    They provided me with specs of the - then unreleased - WH36 series of RPTVs when I emailed them asking for the specs.
  3. f1ng3rs
    f1ng3rs
    There's info on the toshiba Germany website, if you speak german, if not try a translator for comedy translation:
    http://www.toshiba.de/consumer/default.htm
    Is this any different from the current UK Strata model?
  4. jase the space
    jase the space
    Aug 6, 2002
    142
    The Toshiba technical web site has the manual to download!
    http://tesc.toshiba.co.uk/Web/ModelLis.nsf/1f82d70b57a6d36d80256a000042a0fb/d30a8daeaf064a3580256d3400497901/$FILE/3236ZD36P%20European.pdf
    Unfortunately it's only in French/German/Italian/Portuguese/Spanish - no English! But the back page (spec) is pretty easy to follow. Looks like Active Vision chassis (as in PF2) but with the new menu system - basically a PF2 inside a ZD26 body and without the DD sound (also only seems to have 1 RGB SCART whereas the PF2 has 2).
  5. zingo
    zingo
    Thanks for the help! I apreciate it :smashin:
