Infinite Prime maintenance
Discussion in 'Smart Home, Climate Control & Security Forum' started by Benway, Aug 10, 2013.
  1. Benway
    Benway
    Jan 16, 2006
    44
    I need to get into my control panel to wire up a sensor and have a look at my SIM card (think it's been disabled through inactivity).
    How do you disable the tamper function, or disable the internal and external sounder?
    I just tried to get into the unit, thinking entering my code would shut it up, it didn't. After closing it back up and about 10 minutes pain :eek: of the siren going of in my face and going through every option in the menu I managed to turn it off (I can't remember how i did it....)
    Is there an easy way to get in or am I going to have to put ear defenders on while having a look inside?
    I've gone through the manuals and can't find anything.
    Cheers.
  2. Member 351237
    Member 351237
    Jan 30, 2009
    19
    Hi did you get you Infinite sorted?
  3. Michaeltilst
    Michaeltilst
    Aug 27, 2014
    7
    4
    When the alarm goes of just enter the pincode as usual and the alarm will stop
