infinifilm R1
Discussion in 'Movie Forum' started by Gary D, Jan 21, 2002.
  1. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    I have an large collection of DVD's that consistis of R1, R2 and R4 titles, all of them play fine EXCEPT for 2 titles. Both are region 1 and both are from New Line's "infinifilm" range (Thirteen days and 15 minutes)
    When i watch either of these films the aspect ratio changes. in the case of thirteen days it does it about 10 times during the running time and with 15 Minutes it does it about 5.
    Has anybody else noticed this problem? is there a way to correct it?
    The player i'm using is an eclispse DVD-695 and the TV is a Philips 28 inch widescreen.
    thanks
    Gary
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,465
    United Kingdom
    +1,941
    My copy of R1 Thirteen days plays perfectly ok on my Toshiba 210.
    Could be a problem with the lead, though if all your other discs are ok its strange it only does it on these 2 discs.
    You could try changing the cable to see if it makes any difference or switch the dvd player to S-VHS to see if that cures it.
    No doubt you´ll get some more answers!!
    cheers
  3. Family Guy
    Family Guy
    I had a similar problem watching R2 DVD's on my R1 sourced Pioneer player. The only way I solved this one was to turn off the auto 16.9 switching on my TV. May or may not work but well worth a try.
  4. Juzminator
    Juzminator
    Mar 28, 2001
    346
    Ipswich,England
    Yup - sounds like the old "Auto-switching" strikes again.
    I always have my Panny 32PK1 set to 16:9...the only time I change it is if I'm playing a 4:3 PS2 game, then I "Zoom" it.
    Never, ever have the "Panasonic Auto" or "Just" modes on....automatic switching does my fu...flippin' head in ;)
