Infected by virus Help!!
Discussion in 'General Chat' started by thamesider, May 22, 2005.
  1. thamesider
    thamesider
    I have a virus lurking in Restore.
    I know what it is but can't find it.
    The antivirus I used to detect it can't remove it.
    How can I remove it myself is the question ?
    It Is listed as :-
    C:\restore\temp\A0135552.CPY
  2. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    Erm not really sure what you mean.
    Can you not manually go to that folder and delete the file? If it won't let you becuase it is in use, then try starting windows in safe mode (keep tapping F5 whilst your computer is starting up).
    If that doesn't work, download a program called killbox. Apparantly that deletes files which are in use. Never tried it myself though, so I cant confirm if it actually works!
    Sorry if i have got the wrong end of the stick.
  3. thamesider
    thamesider
    The anti-virus that found it, wouldn't remove it, because its in use.
    I tried to find it manually, but couldn't !
    I will try killbox
  4. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    What is the virus's name - website like Symantec will normally tell you how to get rid of specific virus's and will let you download fixes if necessary.
  5. HMHB
    HMHB
    Nov 11, 2001
    25,560
    Nottinghamshire
    +3,892
    If you are using Windows ME or Windows XP you can switch off sytem restore and then do another virus scan. It's good practice every month or so to do this as virus checkers quite often can't access stuff in the system restore folder.
  6. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Tried a different virus software to remove it? I use AVG Free Edition from www.grisoft.com , updates automatically and never had any problems (it does detect a virus from time to time but so far prevented them from causing any harm).
  7. SanPedro
    SanPedro
    Jan 11, 2001
    4,503
    +504
    If you call up the Windows Task Manager can you see it running in processes? Close it from there and perhaps you can delete it then.
    I've also had success running HiJack This (do a search for the download). It spots potentially rogue files on your system and allows you to delete them.
    Chris
  8. w3dal
    w3dal
    Aug 4, 2002
    4,925
    Chelmsford, Essex
    +544
    might be worth running the PC in safe mode then going to the folder dir and try to remove it.
    Dal
  9. thamesider
    thamesider
    I'm using windows ME
    I don't know where this virus came from.
    Its got something to do with :- www.norad.fr/c
    This suddenly popped up in the address bar yesterday afternoon, while I was on queenonline.com. (this was on my home pc, I'm now at work)
    I ran adaware 6, spybot and anity ghostbuster but none of them could find it.
    I then went on trend micro and ran a scan using their housecall, this picked up the virus in the restore section, but couldn't delete it.
    I will try a few of your suggestions when I get home this afternoon.
    Thanks chaps
