Inexpensive multi-region RCE DVD player?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dr Armitage, Sep 10, 2005.
  1. Dr Armitage
    Dr Armitage
    HI
    My Philips player has started freezing after about 20 minutes, then won't play until it's cooled down. [Swearing-edited Ekko Star, please read forum rules]
    Does anyone know of a cheap model that I can buy, just to get me through? It needs to be multi-region and play RCE DVDs.
    Thanks.
  2. Dr Armitage
    Dr Armitage
    I'm told off for swearing. It may be popular on this forum, but it's not big. I feel shame. Now some kind soul answer my flipping question!
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    If £99 is in your budget get down to Richer Sounds and get the Pioneer 575...PJ :)
  4. Dr Armitage
    Dr Armitage
    Thanks for that, but I ordered the Limit DVDA900SE Multi Region DVD Player from Play.com at £49.99. Have I made a reckless error?
  5. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    Nope. It's impossible to make a reckless error when you've only spent £50! Most people who have this player seem to like it. Only issue I seem to recall is that if you alter any of the setup options it loses them when you switch the machine off, hence need to readjust them next time you switch it on. Other then that it will do a fine job I'm sure...PJ :)
  6. Dr Armitage
    Dr Armitage
    OK, thanks for your help.
