Inexpensive but Quality Electronic Crossover
Discussion in 'Subwoofers' started by Cooch, Dec 27, 2004.
  1. Cooch
    Cooch
    can anyone recommend an inexpensive but quality electronic crossover. i want to try one with my pb10-isd. thanks.
  2. bob1
    bob1
    Nov 7, 2002
    4,324
    Sheffield
    +129
    Are you not using an av amp?
    You could try one of these ,i don't know how much or where you might get one.I don't think you will get "inexpensive but quality " but i could be wrong.
  3. bob1
    bob1
    Nov 7, 2002
    4,324
    Sheffield
    +129
    Ok i have found this but it looks like you will need to do a bit of diy with it.
  4. Cooch
    Cooch
    Using Receiver Most Of The Time, But Preamp Sometimes Too
  5. elcid
    elcid
    Might want to consider the Outlaw ICB-1; offers bass management for SAC-CD and DVD-Audio formats' playback needs in addition to variable x-crossover points and slope rates. Is a low cost, high quality, sonically transparent solution. Is sold directly by Outlaw (check their website)...
    -THTS
