Indpendence Day - Special Edition DTS ( How and Where ?)
Discussion in 'Movie Forum' started by toadie, Aug 9, 2004.
  1. toadie
    toadie
    Dec 14, 2002
    330
    16
    Hi there, Just sitting down to watch the above film. How the hell do u turn on the DTS soundtrack ? I cannot find it anyways. Anyhelp much appreciated please please please !
    Many thanks in advance
    Mart
  2. krusty
    krusty
    had the same problem mate.......i got id4 with slipcase and dts. set her to play and zap no dts or day after 2 morro sneek peak. i have now bought a japanese region 2 of the forums,,,, at least this version has dts.
  3. eddiethehead
    eddiethehead
    Feb 21, 2004
    137
    london
    +7
    Have you tried going to the main menu, selecting "languages" (or set up) then selecting dts? (sorry if thats a bit obvious, not sure if you're new to dvd or not :) )
    Mark.
  4. krusty
    krusty
    the prints with dts on the backcover dont even have a select option for dts!!!!!!trust me ive tried that
  5. toadie
    toadie
    Dec 14, 2002
    330
    16
    Hi Guys, Sounds like thats the version I have ! Damn it ! Was quit looking forward to watching this tonight !
    Thanks Guys
  6. Family Guy
    Family Guy
    Er...mine does. Go to languages in the main menu and select dts...hey presto...dts!!
  7. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    34,837
    Bristol
    +8,180
    Easy way to tell if you have the new release. Does it come up at the start with the options to play either the Theatrical Edition or the Special Edition of the film? If it does then you have the original release as the new release with the DTS track just has the Special Edition version of the film.
  8. krusty
    krusty
    yes mine has theatrical or special edition....................and dts stamped on the box!!!!
  9. Family Guy
    Family Guy
    ...then you've been framed!! :D
  10. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    34,837
    Bristol
    +8,180
    Sounds like another case of Fox putting the wrong Discs in the wrong box, only thing you can do is take it back.
  11. brifobwad
    brifobwad
    Nov 29, 2002
    68
    11
    Rosyth
    The VFC number for the DTS version is 21826: the VFC number for the original version is 18616. The number is under the 12 on disk one on both versions. Incidently the UPC number is the same for both versions.
  12. HMHB
    HMHB
    Nov 11, 2001
    26,631
    Nottinghamshire
    +5,334
    Do you have a button on your DVD player to display and change the audio ?
  13. krusty
    krusty
    another way to check also...is even simpler...if the day after 2 morro promo isnt on the menus then it aint the dts version.
