Indecision re. screen
Discussion in 'Projectors, Screens & Video Processors' started by Underscore, Jan 14, 2003.
  1. Underscore
    Underscore
    OK, I'm in two minds. I currently have a 5' Draper Luma screen which, since I first installed it (level and not near a source of heat), has had major ripples. Talking to the supplier, they are happy to replace it or to credit it's value against a DVD player (e.g. Philips 963SA :D) so I have two choices:
    • Get a replacement screen, which will probably be fine
    • Make my own screen using MDF, Dulux Once matt white emulsion and blackboard paint.
    What are other people's experience of the Luma screens and home-made screens? Which route would you suggest?
    TIA,
    _
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,180
    UK.
    +2,721
    Quite a few of us on here have made frames and stretched blackout cloth over them.
    It's cheap and does a good job. In my case it was a stop gap until I got a better screen, but it does such a good job, I've not upgraded it in over two years now.
    If you need higher than unity gain, a proper screen with appropriate material will be needed, but if you want a less than unity grey screen, you can paint the home made one.
    You could always go the Screen Goo route for approx $100 and get the best painted screen for your money - www.goosystems.com
    Gary.
