Incredibles Incredibly cheap
Discussion in 'Shopping, Deals, Discounts & Bargains' started by Rob Pyatt, Mar 8, 2005.
  1. Rob Pyatt
    Rob Pyatt
  2. Rob20
    Rob20
    Jul 3, 2004
    3,282
    +779
    Got my copy free when I joined DvdSoon's i-fidelity card scheme. :clap:
  3. Tejstar
    Tejstar
    Dec 4, 2002
    23,016
    London
    +1,152
    Anyone know how this differs from R1/R2?
  4. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,381
    Bristol
    +10,095
    If its anything like past R3 Disney releases it will be identical to the R1/R2 release with minor audio and subtitle differences.
    Also at £7.99 (with discounts) for a 2 Disc Edition it has got to be worth a look.
  5. raigraphixs
    raigraphixs
    Jul 11, 2001
    66,400
    +26,402
    As i dont have prog scan, i went for R2, as it would be slighter better than R1, R3 both are NSTC. Correct me if wrong. So it cost more £13.25. But it could be my best purchase as the film is very hot.
    rai
  6. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Why would not having progressive scan make the PAL version better? Remember the source material is nearly always NTSC :) Transcoding from one to the other is a difficult job :thumbsup:
  7. Tejstar
    Tejstar
    Dec 4, 2002
    23,016
    London
    +1,152
    I have already pre-ordered the R2 version way back from cd-wow, I don’t think I can be bothered to re-order the R3. Although it is £5 cheaper…
  8. raigraphixs
    raigraphixs
    Jul 11, 2001
    66,400
    +26,402
    What i meant was if i had Prog Scan R2 or R2 equipment, this would give a better picture.
    As the R1/R3 are NSTC, and NSTC has 525 lines and PAL has 625 lines. I have gone for PAL.
    But there is arguments for both. End of day its just my choice.
    rai
    see below;
    http://www.avforums.com/forums/archive/index.php/t-89007.html
    Originally posted by the_pauley
    On the plus side PAL has a maximum screen refresh rate of 100hz
    No it doesn't, PAL is 50hz, unless the TV is upscanning. As for my opinion about R2 vs R1, I generally get R2 discs unless the R1 version is better in a way that matters to me (quality of transfer etc). With most new DVD's R2 transfers are generally just as good as R1.
    R1 - FOR
    * Films generally come out earlier
    * Sometimes exclusive content that's not on other versions
    * Not cut by the BBFC
    * Sound and picture is not speeded up 4%
    * Some plasmas are better at scaling 480p (NTSC) than 575p (PAL).
    R1 - AGAINST
    * Multi region dvd player and NTSC compatible TV required
    * Unavailable on the high street, usually a couple of quid more to import, discs over the value of £18 are subject to import duty
    * 3:2 pull down at 60hz 480p progressive scan creates motion judder
    * Canadian versions have multi lingeral covers which I don't like
    * Lower picture resolution (640x480 NTSC vs PAL 720x576)
    * Second hand resell value is lower than R2 versions
    * Scan lines visible when viewed on a PAL 50/60hz "multisync" interlaced TV, even more visible if the DVD is letterboxed and you have to zoom into it.
    R2 - FOR
    * Works on any DVD player and TV in the UK
    * Available in any DVD shop in the UK, usually cheaper
    * Higher picture resolution (720x576 PAL vs 640x480 NTSC)
    * No Judder with 2:2 progressive scan 576p
    * Sometimes there's UK exclusive content
    * No worries about selling it on
    R2 - AGAINST
    * 4% speed up to 25FPS means audio is pitched up slightly
    * Sometimes cut by the BBFC
    * Audio commentry is sometimes removed because of the 2 points above
    * Old R2 dvd's usually have extras missing compared with R1 versions
  9. Aretak
    Aretak
    Sep 25, 2004
    1,047
    +136
    Not in this day and age. You can almost always get R1 discs cheaper than their R2 equivalent.
  10. raigraphixs
    raigraphixs
    Jul 11, 2001
    66,400
    +26,402
    Sorry, some of those points are not valid, it was copied of another page and some is out of date now, i was manily pointing out the PAL lines stuff, the other points just came with it!.
    Anyway, enough techinal points, l just cant wait for it to drop through me letterbox!.
  11. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,381
    Bristol
    +10,095
    If I can help it I always try and get R2 or R4 as I prefer PAL but most times the price make my final decision and at £7.99 its too good to miss just because its NTSC.
  12. Gorshin
    Gorshin
    Mar 2, 2004
    1,092
    41
    Rayleigh
    The incredibles for £6.72 delivered for platinum members (25%)
  13. Gorshin
    Gorshin
    Mar 2, 2004
    1,092
    41
    Rayleigh
    dvdsoon r1 of course ;)
  14. Marc
    Marc
    Jul 8, 2004
    11,727
    Titchfield
    +1,101
    isn't the source material normally celluloid?
  15. Marc
    Marc
    Jul 8, 2004
    11,727
    Titchfield
    +1,101
    oh darn it, i just missed out on being a platinum member by um.. $29,800
  16. Tejstar
    Tejstar
    Dec 4, 2002
    23,016
    London
    +1,152
    Would have gone for this, but the Incredibles is something I want on release. I’m not prepared to wait a few months! :)
  17. cerebros
    cerebros
    Dec 27, 2002
    1,368
    48
    Leicester
    +44
    The source material is nearly always film.
  18. soup soup soup
    soup soup soup
    Incredibly the incredibles shipped today from dvdsoon, should be here early next week
  19. Tejstar
    Tejstar
    Dec 4, 2002
    23,016
    London
    +1,152
    Damn - don't tell me that! :censored:
  20. Stuart
    Stuart
    Mar 7, 2003
    16,207
    Hampton, Middlesex
    +3,174
    Me too :thumbsup:
  21. imnotrich
    imnotrich
    Nov 7, 2003
    926
    +323
    Yeah I was surprised to see it in packaging yesterday at DVDsoon, and well happy when I found out that they shipped it yesterday as well!!
  22. Gorshin
    Gorshin
    Mar 2, 2004
    1,092
    41
    Rayleigh
    can't argue at £6.79 delivered from soon :)
  23. Marc
    Marc
    Jul 8, 2004
    11,727
    Titchfield
    +1,101
    mine still says preorder :(
  24. Buck Swope
    Buck Swope
    Apr 24, 2004
    192
    16
    Birmingham
    Same here :mad:
  25. Tejstar
    Tejstar
    Dec 4, 2002
    23,016
    London
    +1,152
    I paid over double :(
  26. Marc
    Marc
    Jul 8, 2004
    11,727
    Titchfield
    +1,101
    could you cancel the order? or if you've already got it and it's still sealed, send it back?
  27. Tejstar
    Tejstar
    Dec 4, 2002
    23,016
    London
    +1,152
    My R2 order from cd-wow has been dispatched! :clap:
  28. Cloysterpeteuk
    Cloysterpeteuk
    Feb 5, 2005
    4,799
    Whitby, North Yorkshire
    +1,115
    My Dvdsoon order has been sent.
  29. Aretak
    Aretak
    Sep 25, 2004
    1,047
    +136
    Hopefully CD-WOW will be sending out the R3 orders either today or tomorrow...
  30. Marc
    Marc
    Jul 8, 2004
    11,727
    Titchfield
    +1,101
    mine's now "packaging" at dvdsoon so i expect it'll be shipped today or tomorrow :)
