Included Ethernet cable direct to PC
Discussion in 'Xbox Forums' started by chrisc0le, Mar 24, 2006.
  1. chrisc0le
    chrisc0le
    Feb 13, 2006
    164
    Northants
    +10
    HI all i hope this hasnt been answered before and i missed it,
    I've just got a premiium and i see theres an ethernet cable included, I know i need a crossed ( somethign or other ) cable to make a direct connection form my MCE pc to the 360 now before i order one from the net, can anyone tell me if the included cable is such a cable? and i dont need to order another.
    TIA
    Chris
  2. fatfingers73
    fatfingers73
    Sep 23, 2005
    1,756
    North Weald
    +155
    No, you will need to order a cross over cable.
  3. anchorless
    anchorless
    Nov 29, 2005
    1,065
    Huddersfield
    +43
    I've got my 360 connecting to my PC with a "straight through" cable and everything works fine, I read somewhere that the 360's network port is auto-sensing or something
  4. Shoki
    Shoki
    Oct 25, 2005
    948
    28
    +54
    Had to buy an ethernet card for the pc as mine did'nt have one, then just connected the cable that came with the 360 and works perfectly for conneting to live, although when i tried file sharing with the pc it said i needed to download some software to the pc but hardware seemed fine.
  5. ptogscot
    ptogscot
    Jul 10, 2005
    Yup same for me - I do have a cross over cable but left it at a friends house so thought I would give the one in the box a try to get on live - and it works no probs! Plus it aint lurid blue like my other one so looks slightly better with the 360!
  6. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,158
    Bristol
    +9,898
    Before the 360 was released everyone thought that a crossover cable would be needed but it turned out that the included ethernet cable will do just fine.
  7. chrisc0le
    chrisc0le
    Feb 13, 2006
    164
    Northants
    +10
    Get in!! glad i checked back
    Thanks lads
    ( and ladies in case! )
    Chris
  8. stevos
    stevos
    May 16, 2004
    6,192
    +585
    I can't seem to get this to work. The network wizard thing states limited or no connection and states no ip address assigned.
    Any ideas?
