Inakustik Cable
mickg007
Building a new house and about to wire it out next month. I was thinking of buying one of the following speaker cables for home cinema and to also to all ceilings for room audio (sonos+sonance)
Inakustik Star - 2 x 2,5 mm² | hifisound.de | The speaker specialist
or
Van Damme - Specifications - Blue Series Studio Grade speaker cable
I would say max run for ceiling speakers will be 15/20mts and main room run for connection to Denon Amp and Linn Sekrits will be 4/5mts
I cant find out what AWG either of these are and I am wondering should I be using the same cable throughout. I don’t mind spending a good bit on the 5mtr run, but don’t want to cheap out on the other rooms either
Any suggestions / help would be great
Also -
PSM1
The Van Damme Blue is often recommended as a good value cable and 2.5mm is the normal recommended thickness too. Both look fine though so either should be fine.
Joe Fernand
AVForums Sponsor
A key difference being one is a Shotgun vs. a Coaxial, you will find the VDC Blue (Coaxial) is easier to work with.
Do your local building regs require CL2/3?
Ensure you also follow local code on installing in-ceiling Spks (you may have to budget for fire hoods).
Also think about sound going into spaces above the Spks!
Joe
28061
I used the van damme in my new build recently. It's amazing cable. So flexible and easy to work with and no 'memory'.
mickg007
Joe
I will chat with the builder about fire regulations.
Is there a DIY job you can do for surrounding the speakers to stop sound leakage ?
Mick
PSM1
You need special cable for outdoor use. The normal blue van damme is not designed for outdoor use.
shortyav
Mick
I'll often have volume appropriate sealed boxes made with fire retardant plaster board and fire resistant sealant. Bit of a time consuming pain but it helps with sound quality, sound leakage and regs.
