Kootuu
- Joined
- Nov 18, 2002
- Messages
- 860
- Reaction score
- 29
- Points
- 256
Hi All, started work in my garage conversion and getting close to having to decide on speaker placement. I've currently got some Monitor Audio RSFX Bi-Pole Speakers which I had planned on mounting on the rear wall, to the side and just above where I sit.
Unfortunately the room dimensions mean the couch will have to be right against the back wall, so I wondered if I might be better off installing some in-wall speakers on that back wall instead of the bi-poles. I'm not able to mount the bi-poles on either of the side walls.
The front 3 are all in-wall Monitor Audio CP-WT240-LCR speakers, and was thinking I could either use 2 of those again or something similar with a pivoting tweeter. Also going to have 2 ceiling speakers for a 5.1.2 setup.
Any thoughts on what would be best?
Chris
Chris
