In wall speakers
Discussion in 'Home Cinema Speakers' started by Dave777, Jun 11, 2003.
  1. Dave777
    Dave777
    Oct 25, 2002
    489
    Gatwick
    +16
    Has anyone had any experience with in wall speakers. I'm planning Kef eggs or Gallo balls, but someone has mentioned in wall speaker. If I was to spend around £800ish on 5 or 6 speakers for an in wall system and get a CHT-10 from Uncle Eric would it sound better. Subjective I know but I know very little about these. (and the builder needs to know!!)
    Dave
  2. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    I think Uncle Eric has some recent and relevant experience with in-walls. Give him a call.
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,039
    You can get a nice sound from in-walls. You don;t have much of a budget though for super duper ones. Heybrook do a speaker called an IW81 that is excellent for the price. I've used them alot. Definately under £200 a pair.
    I saw some M+K ones that had good fixings and of course the Linn Sekrits are worth looking at (although out of your budget)
    Gordon
  4. uncle eric
    uncle eric
    They certainly do Gordon but these fixings are only of value when used in drywall fabrications.
    Solid brick is another proposition.
    A 4.5 inch chase brings you into the cavity (if double wall, ie exterior boundary wall) which of course offers it's own problems.
    Just finished x 6 of these (in wall S-85's) as part of an install for a customer.
    Good excercise though :D
    System includes Denon 3803, Pioneer 757 and Velodyne SPL800.
  5. Dave777
    Dave777
    Oct 25, 2002
    489
    Gatwick
    +16
    Eric, I have a soft block wall, which is the inside wall of a double skin cavity brick wall. The conversion will need plasterboard being attached to this with insulation. So I have the thickness of the plasterboard, the insulation and anything I chase out of the soft block. Will a decent in wall speaker fit into this Ok?
    Gordon, do I need a bigger budget to do this well? It may be available if I jiggle some things on the conversion. Don't tell the wife!
    Dave
  6. Dave777
    Dave777
    Oct 25, 2002
    489
    Gatwick
    +16
    ...or does anyone lnow any good web sources of info on in wall speakers and their installation?
    Ta
    Dave
  7. CarlB
    CarlB
    Jan 8, 2001
    1,293
    Cambridgeshire
    +224
    Well the M&K website allows you to download manuals for their inwall speakers, so you can see the fixing instructions.
    www.mksound.com
    I have some inwall SW85's mounted in the ceiling for the rear effects channel, they are great. However, I think they were about £400 per speaker so they aren't cheap, but at least you may be able to get some info on the fixing requirements.
  8. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    I've been thing about a pair of inwalls (or maybe just the one) to use as a centre rear(s) to go with my Celestion C series. Does anyone have an idea if Celestion do any in walls for a close tonal match or what else should I consider?
  9. jaybeegee
    jaybeegee
    Jan 8, 2003
    73
    machester
    hyperfi advertise heavily in whathifi mag and have kef ceiling speaker cheap - probably discontinued range. these speakers any good, anybody?
    jay
  10. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    I'm going for a 3 KEF ci2000 on the front and maybe another 4 across the back or even drop to the Ci1500 or Ci1000.
    Having had the Kef Ref 3.2;s, doubt this will "loose" any thing that the HGS-18 can't do, so watch out locals.........
    Am using a pair of KEF 70's and whilst they lose the detail, can;t blow em up............ YET, up to +10 with each seing 300 watt HK amps.
    Guys decent sub is the KEY - trust me.
  11. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    Nathan
    Did you get the kef ci 2000 & if so what do you think of them
    i am thinking about these in wall's for a while now
    P@T
