In Wall Speakers installation
Discussion in 'Home Cinema Buying & Building' started by Starkiller, Apr 11, 2005.
  1. Starkiller
    Starkiller
    Nov 3, 2003
    202
    +3
    Im running out of (wife friendly) Speaker options :lease:
    any ideas what it should cost to install 6 inwall speakers, thinking of MA silver CP's (the center can just go on a coffee table or shelf)
    the sizes are 235x3?? ish x 100mm deep
    The walls are cavity and plaster board.
    Cable's are run under floor, so need to run them behind the plaster board as well
    Would do it myself, but wife wants it doing quickly and neat :suicide:
    I live in Staffordshire BTW
