In wall speakers - Around £1,500 to spend for LCR
thomasjohnflynn
HI All,
I am looking at swapping my front sound stage of PMC GB1, DB1 and going in wall.
The problem I am having is the number of in wall speakers out there and the difficulty in auditioning.
Looking so far at:
Polk
Totem
Speaker craft
Definitive Technology
Tannoy
Proficient
List goes on............
I already have a BKXLS400 sub and some MK Column surrounds so its really just the front three.
Preferences are about 80% movies 20% music. I have loved the PMC's but think maybe something a little more movie centered.
Also can't go with the Wafers as they will be to deep for the space I have.
Any help any one can offer in what they have heard and liked would be great.
Tom
megson
Hello
MK do some great inwalls. I have heard the inwall 150's and they were stunning. The inwall 95's would be more or less around your budget.
They would go well with your column surrounds.
Regards
Megson
Arcam_boy
Try Allan @ IdealAV.
I've also listened to the 150 in-walls at Al's and they sound stunning, although a bit over budget. As Megson has rightly said 95's would fit your budget although not quite in the same league as the 150's.
You seem to be ruling out some of the more main stream brands...
PMC do the Wafer in-walls and I'm guessing you're a B&W fan?
Kef do some superb in-walls
Likewise for Monitor Audio and B&W. Have a look here HiFix the Hi Fi and Audio professionals at the brands listed and the in-walls available.
thomasjohnflynn
HI Arcam_Boy,
I have discounted the PMC Wafer's due to there depth, they will be installed over a fire place with the TV above the centre.
Never really heard B&W's to be honest so not sure what they would be like.
I have discounted KEF as the last set of KEF speakers I owned IQ70 I really didn't like. Found them very bright.
I moved to my PMC's and have really liked them, not changed them for years now.
How much do the MK 150's retail for?
Tom
PSM1
I have a feeling that inwall speakers for your budget are going to be a downgrade interms of sound quality compared to your current speakers. Hence you may end up feeling disappointed after the change. If possible go and listen to them first to ensure they are OK.
Gboardman1959
HI Arcam_Boy,
Tom
Hi I have the MK150s they are£995 if you are anywhere near Yorkshire ideal av have a must see demo rooms of all the MK inwalls
thomasjohnflynn
Ah... Thanks for the reply but sadly that is way over my budget so I don't even want to listen to them for fear of being disappointed.
I think I now have it down to either the MK IW95 or the Definitive Technology UIW RLS II. Both over my initial budget I know but then a little creep is aloud surely.
Anybody heard the Definitive Technology UIW RLS II?
Also if I go for the MK IW95 will my BK XLS400 be enough?
Thanks all.
Tom
thomasjohnflynn
I think your'e right in terms of music, I know my PMC's are great music speakers but as I am now much more movie focused I wonder if the loss will be that great.
I am also really keen on the idea of getting some of my lounge back by using in-walls as well.
I will definitely try and have a listen first though.
Gboardman1959
That's what happend to me I went to ideal av just for the demo and ended up spending my inheritance even if you went for the 95s I'm sure you won't be disappointed .If you could possibly get up to Ideal AV you would be in for a real treat he as got one of the best setups for in wall speakers you will ever see
Geoff
thomasjohnflynn
Ok, I am now in the situation that I need to demo an in wall system to give me an idea of what I need to buy and at what cost. I have looked and looked and feel like I am getting to the point that I have no idea what to purchase.
The MK IW95's look good but I am worried that MK have not moved on much in the last few years, this is purely my thoughts at the moment and is not based on any actual listening.
Does anybody know of a place to demo some in wall speakers in either the west midlands area or central london?
Thanks for your help.
Tom
daytona600
genelec do in wall kits for there small active monitors
Gboardman1959
Exactly why change a winning formula
thomasjohnflynn
Fair enough, anybody know where I can get a listen to some 95's near the west midlands or london?
Tom
Baggy
Tom
I have the 150's as my front LCR and 95's as surrounds. I'm more east midlands but you're welcome to demo
thomasjohnflynn
Thanks for that and very kind of you. I have a fear though i am going to end up loving the 150's. I am booking some demos up now so will come back to you if you dont mind.
Tom
Arcam_boy
The PMC in-walls aren't that deep...
wafer2-iw
100mm according to the spec sheet, my B&W's are 95mm and they were pretty shallow.
I still wouldn't rule out B&W, not as detailed as the 150's but a warm full sound and certainly a very cinematic sound!
Unfortunately in-walls aren't the easiest speakers to demo but if you're looking at spending £1500 its worth getting a decent demo before parting with your money although that may be doubling if you go down the 150 route! :devil:
thomasjohnflynn
wafer2-iw
Thanks Arcam_Boy,
I think I may have not been clear though, the depth I should of really said width / shortest edge as I will place the centre under the tv.
Funny you should mention the B&W though as I am going to arrange a demo for next week in London of some B&W in walls, so will let you know how I get on.
Tom
thomasjohnflynn
wafer2-iw
Also regarding the PMC in walls, how would they compare to the MK 150's as they are the same price. I will be running a sub so don't need the extra depth they would offer as I would run them small with I think the standard 80hz crossover.
Thanks again
Tom
Arcam_boy
Which model B&W's are you going to listen to?
I've not personally heard the PMC in-walls but guessing they'd sound pretty good and I'm guessing you're already a PMC fan if you're currently running there speakers?
I do like the 150's and the dynamics are exceptional however for me, and this is a personal preference, they are too dynamic and bright and instead of the warm cinematic experience you would get at a cinema you get bags of detail and it can sometimes be a little too much even in a properly treated room and 400w per channel being fed in to each one!
If I personally had £3000 (£1000 x 3) on three in-walls I'd probably opt for the B&W Signature in-walls. Stunning sounding speakers, not quite as dynamic as the 150's but a fuller more cinematic sound and much better with music for the odd occasion you fancy spinning a music cd.
However the Signature's are on the large side so you may have to look if you can accommodate them in your room :rolleyes:
thomasjohnflynn
I think to be honest I will try if i can to stick closer to my budget so something like the B&W 7.4 or the B&W CWM LCR 8. I need to go and have a listen now though to get a feel.
Yes I am a PMC fan but that is based on a limited amount of listening to other brands so I am open to look around.
Tom
Baggy
I was thinking of getting the B&W Signatures since I'd been using B&W 804s and liked them. I'd also heard the B&W Custom Theatre speakers at Dr Gekko's, whilst not in-walls they were behind his screen and reinforced the B&W's appeal.
Whilst I was still in the planning stage I had a demo of Allan's MK 150's which I also liked and the size of them fitted in with my AT screen plans which made me unsure of which direction I should go.
Then by chance I came across someone selling a used set of in-wall 150's on here and they were at the right price so that helped make up my mind.
bluedroog
The Wafers are supposed be just as good as their more traditionally shaped counterparts, that said if I recall correctly they never got the 'i' makeover and are effectively in wall of the '+' version.
Just a though actually, i know you said the Wafers were too deep but were you aware they com in two versions? An in-wall and an on-wall? Could the on-wall be an option?
KelvinS1965
Just a suggestion: Why not put the centre above the TV as if it's going above a fireplace then IMHO it's too high anyway and putting a speaker under it will make it even more so. This way perhaps you could keep your PMCs and just put a single wafer in wall above the TV: They have tweeters that can be angled which should help.
I've often considered changing my surrounds to wafer 1s myself as a better match than my M&K K4s and K5 surrounds as I have TB2+ fronts.
Member 518284
Thanks all.
Tom
Hi Tom
If you want to listen to both IW150 or 95 I'm pretty sure you wouldn't be disappointed with either, the 95's for me anyway really do make a fine front speaker with loads of speed,attack and presence and are more than good enough, I use them as fronts, extra height fronts, back surrounds and all 4 ceiling mounted surrounds in different rooms
You wouldn't be disappointed I'd have thought and I'd recommend having a demo of them
I would recommend you go to Gecko but Rob doesn't have inwalls on demo
And theirs no reason your BK sub wouldn't go with the MK's but you might want to change it in the future
Allan @ Ideal AV
Trending threads
Latest News
Linn announces Majik DSM digital streamer upgrade
  • By Andy Bassett
  • Published
Sony announces WH-1000XM4 noise cancelling headphones
  • By Andy Bassett
  • Published
McIntosh launches C22 Mk V preamp and MC1502 power amplifier
  • By Andy Bassett
  • Published
Marantz unveils 12 Series Special Edition models
  • By Andy Bassett
  • Published
Samsung Galaxy Note 20 smart phone models launched
  • By Andy Bassett
  • Published
