In wall speakers - advice please
Discussion in 'Home Cinema Speakers' started by redface, Nov 19, 2003.
  1. redface
    redface
    May 27, 2003
    67
    I am planning to get a false ceiling put in to my lounge to sink some halogen spots into and it occured to me that I may as well also get some speakers sunk in as well. I am likely to plump for the KEF CRi 130 QS or QRs
    So I have the following questions:
    1. Are these KEFs any good ?
    2. Are the QS and QR identical aside from the square or round casing ?
    3. Should I have 4 or 5 speakers for surround sound ?
    4. If I have 5, is it ok to ceiling mount the centre speaker or does this ruin the effect ?
    5. Anything I should watch for in the install ?
    All help gratefully received
    :confused:
  2. bobbypunk
    bobbypunk
    try the brand sonance
