Question In-wall speakers : 2 or 3 way ? with or without a backbox ?
Discussion in 'What Speakers Should I Buy?' started by AEM, Jan 6, 2017.
  1. AEM
    AEM
    Jan 3, 2017
    France
    Hello AVforum users
    I'm looking at in-wall speakers for a hifi installation with a 100W stereo amp.
    I understand that there are some models which come with a closed backbox, whereas most models are open at the rear side (ie inside the wall). Does this have any influence on sound quality or vibrations ?
    Also, within the same price range, I would favor 3-way speakers over 2-way models, but would appreciate to hear your advice. I underline that I will not have a subwoofer and therefore am targeting models with 8 inch boomers.
    Thank you
  2. Seriously Ltd
    Seriously Ltd
    May 17, 2011
    8,002
    St Albans
    +4,522
    Procella audio have some large driver in wall speakers that sound stunning.
    MK Sound have fantastic 2 way designs that can be mated with their dual 8" in wall subs.
    KEF also have some good solutions but will require their in wall subs for the low end.
  3. AEM
    AEM
    Jan 3, 2017
    France
    Thank you !
  4. Smurfin
    Smurfin
    Aug 13, 2002
    21,458
    +4,392
    You've not mentioned budget?
    In-walls are often more expensive than their conventional free standing counterparts, but given the choice I will always go in-wall!
    Re: back box or not? All depends on your wall construction and the speaker design, but personally I prefer ones with back boxes as guess work is taken out of the equation.
