In-Wall Speaker Suggestions..
Discussion in 'TAG McLaren Audio Owners' Forum' started by Joelc, Aug 5, 2004.
  1. Joelc
    Joelc
    May 16, 2004
    414
    +5
    The title explains most of it.
    I am currently running M&K speakers in a 5.2 setup. Specifically:
    -- L/C/R are M&K MPS 2550 http://www.mkprofessional.com/mps2550.html
    -- SR/SL are M&K MPS 1625 http://www.mkprofessional.com/mps1625.html
    -- Subwoofers are M&K MX0350 THX MKII http://www.mksound.com/mx350.html
    I want a stealthier look and am now considering in-walls. While I do like the M&K sound and M&K does make in-walls I would like feedback on experience and thoughts that others may have.
    Other pertinent information is:
    -- TMA 100x5R, AV192R, DVD32R
    -- Use is 85%+ HT with the balance being music.
    Look forward to everyone's feedback.
    Thanks,
    Joel
  2. sijones
    sijones
    Nov 5, 2001
    636
    Reading
    +36
    Hi Joel,
    I use 7 M&K SW-150s (these are the in-wall version of the S-150 speaker) with the MX-350 sub and they sound great. You will need a 4" deep recess in the wall to house the speaker, which can be difficult to achieve. I don't know if you have any children but a great benefit of these speakers is that they have a metal grill and this prevents any small fingers from damaging the speakers.
    Regards,
    Steve
  3. Joelc
    Joelc
    May 16, 2004
    414
    +5
    sijones:
    Many thanks for the feedback. The need for 4" of wall depth is not an issue as I will be tearing the room apart.
    The first issue is really the sound... are there more musical and/or better value in-walls. The ones that I have heard good to great things about are the TRIAD Golds. Any thoughts?
    The second issue is design... I have been advised that the better in-walls have self contained boxes/enclosures which the M&K's do not. Any thoughts on thi issue?
    TIA,
    Joel
  4. PhilCTTE
    PhilCTTE
    Aug 28, 2001
    1,801
    W.Mids
    +156
    I only got round to auditioning one set of in-walls and I was totally blown away. If you have a B&W dealer nearby go and audtion the 8NT signatures. Prior to this I had a pair of KEF 105/3 with 2 ASW800 subs. These B&W in-walls have such a good bass response that I only use the one sub for HT now. I ended up building an extended chimney breast to house them but it has been worth it ! They cost £1500 each
