In wall speaker setup (maybe klipsch)
Discussion in 'Home Cinema Speakers' started by warjam1945, Jun 20, 2015.
  1. warjam1945
    warjam1945
    Jun 20, 2007
    99
    +18
    I am wondering have anybody any experience with the klipsch r5502-lcr speakers or kilpsch speakers in general . I am thinking of going for 3 together behind a acoustically transparent screen and maybe 2 Klipsch RP-240S-BLK as back surrounds.
    Has anybody any suggestions of this system or a similar system with in-walls at the front?
    My room is about 4m by 6m with 2 rows of seats if that helps the answers.
    Thanks in advance.
  2. Ideal AV
    Ideal AV
    Jan 12, 2011
    11,150
    2
    Normanton
    +6,455
    the MK IW150`s really will take some beating if within your budget
    you get the sound almost exactly like the S150 but flushed inwall, its a great system
    Allan
  3. Arcam_boy
    Arcam_boy
    Jun 13, 2006
    12,065
    2
    Birmingham
    +2,386
    @warjam1945
    I'd second the MK IW150's having heard them at @Ideal AV they take some beating!
    Obviously depends on your room and if you've started prepping for in - walls you could try the MK MP150's, which have been very recently reviewed, and attach them to the wall and put your acoustic screen in front of them.
    I've done this recently for a friend in a garage home cinema set up and again they sound superb and a lot easier to install then in-walls IMO!
  4. warjam1945
    warjam1945
    Jun 20, 2007
    99
    +18
    hi guys, thanks for the reply but these are way outside my budget. I am trying to stay below 1500 for the speaker setup at the moment. Is there anything you would recommend in this range?
  5. Ideal AV
    Ideal AV
    Jan 12, 2011
    11,150
    2
    Normanton
    +6,455
    yes, take a look at Dali Inwalls, very good :smashin:
    can you tell us a little more, is £1500 for a 5 channel inwall + subwoofer
    also what amp will be driving these
    Allan
  6. warjam1945
    warjam1945
    Jun 20, 2007
    99
    +18
    yeah, its 1500 with the subwoofer and the amp is a Onkyo TXNR838. I am going with that amp because of Atmos support.
  7. warjam1945
    warjam1945
    Jun 20, 2007
    99
    +18
    what should i be looking for in a speaker? Size, watts, materials? I dont have a clue and cant seem to find a guide. Any help would be great.
  8. Ideal AV
    Ideal AV
    Jan 12, 2011
    11,150
    2
    Normanton
    +6,455
    maybe give one of the forum sponsors a call whose is experienced with in walls setups and I'm pretty sure he'll be very happy to help you
    Allan :smashin:
  9. Jag @ Epic Home Cinema
    Well-known Member AVForums Sponsor
    Jun 2, 2014
    1,779
    146
    Langley, East Berkshire
    +2,245
    A 4m x 6m room is a good size. Atmos should work well in there. You'd want good coverage and a response that's well balanced off axis as well as on.
    A few options. If you could go on wall with slimmer profile options that could work really well.
